1 - 11 of 11 Posts
I am trying to save and restore the original interior rear view mirror from my '68 and have some questions.
It has two problems. The glass is needing replacing or re-silvering and the lever for switching the day/night mode is broken.
My questions are...…
1) Is there any place you can get a replacement lever aside from a donor mirror. I'm doubting it but it never huts to ask. I tried gluing mine back together and had exactly the luck I expected......none!
2) Replacement glass is available from Paragon Corvette for $40.00. I assume it's reproduction and wonder about the quality and fit. Anyone had experience with these?
3) Can any place that re-silvers mirrors re-do do a day/night mirror?
4) Is it true that the glass just fits inside the rubber and that no adhesive was used to hold it in. I didn't know if the yellow substance that came off of the back of the glass and stuck to the rubber was adhesive or part of the mirror backing?
5) How is the rubber attached the stainless steel body of the mirror? I had soaked my mirror in hot water to soften the rubber to get the glass out and in the process, most of the rubber detached from the body of the mirror. An inch and a half of the rubber at one end will not come loose though. On the part that did come loose, there doesn't seem to be any trace of adhesive.
Thanks..…..Dave
I couldn’t find any of the answers to your questions when I wanted to restore my mirror. I purchased a reproduction mirror and it looks real close to original.
Roger
I had my OEM mirror resilvered and several years later you could see where the silver had failed originally and it looked just as bad so I'd either get a new glass (if you ca find it) or just get a repro mirror. I got a repro mirror and like it. I did contact Paragon Corvette with respect to a replacement glass and was told what they had would not fit my 1969 mirror properly and the Corvette mirrors were a slightly different shape.
I took mine to a glass shop and had them cut a regular mirror to fit.
as far as the lever, you can get a substance called "pig" epoxy putty. it is like clay. you can shape and mold it to match your original lever. it is machinable , drillable and you can paint it after it sets
just a thought
Chris who did your re-silvering?
Some antique restoration shop in Houston, not sure if it's even still in existence since I had it done probably 20 years ago so I can't provide any guidance for someone to do that for you. Like I said, the resilver job did not last long.
No worries, just wanted to know who did it, because I stand by the earlier recommendation. Glad it wasn't a bad experience from that source.
just a thought
Does it function correctly between day and night? Reason I ask is because when I took my original apart, I noted the glass was thicker at the top or bottom - not the same thickness throughout. I suspect your shop used a sheet of consistent thickness glass.
Discussion Starter #11
I am the OP and apologize for not getting back to this sooner. Thanks for all of the replies.
I think my two choices are to send my mirror to The Mirror Lady or to buy replacement glass from Paragon, replace my broken day/night switch lever, and do it all myself. My metal body is in excellent shape.
I have a line on a donor mirror to get the day/night switch lever from. I did look into the Pig Epoxy that was mentioned to fix my broken lever and it seems it is only sold in bulk (like six 4 ounce tubes) with a minimum price of about $50.00.
I Googled "mirror re-silvering' in the Orlando, FL area and got two hits. I went by one place which was close to me and they told me they don't do anything like that. I called the other place which was called Mirror Mirror and they told me they were a hair salon! (I had to laugh at that one!) With the results some have had with re-silvering, maybe that isn't the way to go.
I did contact The Mirror Lady, spoke with Dennis over there, and found out the following....
a) The cost for the mirror restoration is $95 plus $12 for return shipping.
b) Yes, they can replace my broken day/night lever switch but that is extra but I didn't ask how much.
c) They use new glass! They do not re-silver your old glass!
d) I said my rubber frame has some light discolored spots that I could not remove with detergent and scrubbing. He said they have a solution that they use that does a good job. That most light staining would clean up but if it was really dark, it might not.
e) They DO NOT sell individual parts if someone was wanting to do their own restoration.
f) There is an adhesive that is used to attach the rubber frame to the metal body of the mirror. I wasn't sure if it was supposed to somehow snap into place.
For the price, The Mirror Lady is probably the way to go. I like fixing my own things when I can though, so I haven't made up my mind which way to go yet.
Dave
1 - 11 of 11 Posts
