I have a 69 Camaro that currently has a manual steering box. I would like to install an IROC steering box but I am concerned that it won't fit. My Camaro has a big block with Hooker Super Competition headers (2" primary). The header barely clears the manual steering box right now.
Anyone know if it will fit?
it is common to have to ding in header tubes a little bit- which is understandable, given that these cars have only been around for a little over 40 years..
I have run the combination before. It worked with the headers I used, can't remember what brand they were anymore though
Does the IROC box have about the same dimensions as the original power steering box? I looked online and hooker shows that those headers should work with the original power steering box.
It is the same physical box.
I swapped out the original 68 PS box with a Lares 972, which is a stock 1st gen quick ratio box with IROC internals. We had to put a small dimple in the Dynomax headers. Otherwise, no issues.
Discussion Starter #8
The other question I have is that since I am converting from manual steering I will need a pump too. Obviously I can use the pump from the IROC Camaros (with longer lines) but what other pumps will work well with the steering box?
I too have a 69 BB with the IROC steering box. I used the original PS pump and hoses. I got the adapter fittings and the rag joint from Lee manufacturing to complete the hook up. You need the fittings to hook up the hoses. I have Flowtech headers that just touch the box. I also installed a 14" leather wrapped re-po Corvette steering wheel with the bow tie horn button to complete the steering and it looks like it came from the factory.
