Hello guys/gals,
I need some info on roots blowers. Is it possible to install, i.e. a Weiand 177, on a '67/'68 350 WITHOUT the scoop stickin out of the hood!?
Would it be possible when you don't put scoop on the carbs, just an airfilter and with a cowl-hood. But will I then get enough cold air into the rootsblower, or do I need a smaller rootsblower?? And will I loose some power because air is not rammed into the carb?
Does anyone have any suggestions or ideas how to do this?
(I'm only a few k away from a camaro, but I just want to know if it is possible, because scoops are illegal here, so.....)
Thanx, David
Discussion Starter · #3 ·
Thanx alot Jody, but has your friend got the scope under his hood, or does he has no scoop at all?
David
