68 Camaro RS restored mostly original, 68 Camaro Pro Touring build in progress
Hi,
Starting a pro touring build with a 68 and concerned that maybe the unibody isn't straight. You can see it is resting comfortably on 3 jack stands while the 4th hangs out on its own. The jacks are adjusted equally and the garage floor is pretty straight and even. Is there a way that I can tell if it is bent without bringing it to a shop with a frame machine? Someone did work on the car before I bought it, and the panels were all aligned very nicely before I took it apart. Doors, trunk, fenders, hood, all had close, even gaps, but not sure if that is a reliable indicator.
Thanks,
Marc
Thanks,
Marc
