It's hard to say with that bolt out. Hopefully the intake loosened up enough to allow a little coolant past the intake gasket and it got into the intake passage. Hopefully, tightening the bolt again will make it stop. Just don't put the gorilla grip on it trying to make it stop.
When you pressurize the cylinder, it's not uncommon for the valves to leak a little. So I hope what you're seeing is a little leakage causing the issue. But then again, I'd only expect you to see it when pressurizing the cylinder ajacent to the loose bolt. If not, then perhaps you have a head gasket problem.
When the engine is back together and running again, there is a simple test most auto shops can do. It involves sucking the air from the cooling system and bubbling it through an indicator liquid. If there are combustion byproducts in the cooling system, the liquid will change color and indicate a bad head gasket.
If you remove the radiator cap and pressurize the cylinders does the leak stop?
