my engine has trick flow 195s,10.3 comp. airgap and 1 inch spacer. and xe 274 comp cam,1.6rockers. im running a holley 670 street avenger series carb. im thinking of getting a 750 with mechanical secondaries. i wanted to know if a 750 would make a difference? i would appreciate any help. thanks
the lope is soooo nice at about 800 rpm its has a 2800 stall w/ lockup on a 700r4 from bto with 3.73s and the 670 isnt giving good top end power.
Go with the 750, but keep it a vacuum secondary. The tranny will use the vacuum seconds to better advantage then it would a manual second. JMHO
thanks guys
CID * RPM * VE / 3564 = CFM
If you have 100% VE (which is rare) at 7000 RPM (which is high for all but a well balanced motor) your CFM on a 350 SBC would be 708CFM. A more realistic figure would be 350 * 6500 * 0.95 / 3456 which is 625 cfm. So IMHO, a 650 CFM vacuum secondary carb is ideal for a 350 SBC with an automatic tranny.
