1 - 2 of 2 Posts
I am planning to build my own exhaust-system (X, maybe H). I am planning to use a diameter of 2.5", and as I am a designer in a company that only uses stainless steel I can have all the stainless parts extremely cheap. But now I am stuck with a problem: the diameter is 2.5" but the thickness is 1.5mm (0.059"). Normally the exhausts here are about 1mm (0.039"), should I use the thicker steel or not?
I don't know if there are more negative things besides the added weight and more difficult to bend...
Sounds OK to me, other than the extra weight and being able to bend it like you said . . .
You might check around to make sure you can get acces to a mandrell bender that can handle your material --- I tried to get a couple local shops to bend some .120" mild steel tubing and they all were afraid they would damage their bender trying.
1 - 2 of 2 Posts
