Finally, I get to drive my 69 RS Convertable.
Anyway, when I am in 4th gear accelerating and then let off the gas, it pops out of gear. I hope I don't need to pull the tranny to fix this as I am finally getting to completion after many years.
Any ideas what the problem is?
Detail: 69 RS 350. Muncie 4 speed with Hurst shifter. All new motor/tranny mounts.
Usually caused by a worn pilot bearing in the rear of the crankshaft. Lets the input shaft of the transmission wobble a little bit and the syncro sleeve and shaft teeth get worn. If the pilot bearing is new and tight, you may need some transmission work, although might first check to see that the shifter is putting it all the way in gear. Sometimes you can remove a shim gasket in the rear of the case and tighten up the clearance at the input shaft and help this too. Parts are expensive, hope it is a simple fix.
This is caused by either the shifter not going all the way into gear, as stated above, or the pilot bushing, but more than not, the end play in the mainshaft/input shaft is too large, allowing the synchro ring and slider to not engage the input shaft deep enough to hold the gear in. This will usually show up in decelration, not cruise or acceleration.
The fix is to pull the gearbox and check the front to rear play on the input shaft, with the outlut shaft pulled back all the way in the case/extension. The input shaft can be shimmed between the front bearing and the thrust face of the input shaft, but the damage to the synchro blocker and input shaft may be too far gone to completely fix it from the outside.
Please note, it could also be a detent problem on the side cover or a bent or worn out shifter fork/synchro slider groove not engaging high gear deep enough as well.
Stop screw on shifter could be too far in, set for a more shallow second gear stop. Worth checking as well. Set screw for deepest gear engagement between sets 2/4 and 1/3.
[This message has been edited by IgnitionMan (edited 08-29-2000).]
I am pretty sure that I replaced the Pilot Bearing when I put the new motor (crate Targetmaster 350) in about 8 years ago. I have not driven it til now since my restoration project got interrupted for personal reasons until this summer.
I think there might be a little interferance in the shifter linkage against the center hump. It sounds like it is hitting a little when I shift. Maybe it is keeping it from locking into gear (although I think I hear that when shifting into 3rd).
I seem to recall I don't feel a very solid "click" when shifting into 4th, is there some type of detent mechanism that click into gear?
As far as the rubber boot, It is not an issue since it is not really bolted on yet. I wanted to wait til I get this fixed before I mount the center console.
Reeko, the guys have listed all possiblities. But check linkage adjustment and clearance first. It could be that simple. Might have to shorten the 3/4 rod a freckle.
