1 - 2 of 2 Posts
Im starting new post, now that i own this motor.
Chevy 383 all forged 500+ hp stroker motor
Late model 1 piece rear main block bored +.030
Align Honed, Decked to -.005”
Eagle forged steel crank turned -.010 due to factory taper on journals
Eagle 6.0” H-Beam rods, SRP forged flat top pistons
Rotating assembly re-balanced to w/in ½ gram after turning
Edelbrock Victor JR. heads angle ground to 67cc for 10.49:1 cr. w/.040 Cometic head gaskets. 215cc intake runners, 2.08 intake, 1.6 exhaust, 7/16 rocker studs.
Crower Stainless Steel 1.6 roller rockers, custom length pushrods
All ARP fasteners, Head & Main studs, oilpan studs.
Moroso High Pressure pump w/factory welded p/u & matching GenIII Camaro Pan
Chevy “847” cam (made by Crane)234/242 .539/.558 112 LSA , Crane high rev factory style roller lifters,
All new retainers & “spyder”. Stainless SPF balancer, Double roller chain.
i got the motor for $2500:hurray:
Now ive got to buy intake (needs to fit under standard hood), carb, ignition, etc. Any ideas?
on the ignition, i Know HEI distributors hit firewall....i would like to avoid drilling holes for MSD box....is there another way to go about it?
thx for the responses.
Man you litterly stole all them good parts for that price.
You say a Roller; Hydraulic or Solid ?
I don't think you will have any hood clearance issues with any Intake or Carb combinations with a 3rd Gen SBC a 1st GEN if that's what you're putting it in.
If your not running a CD Module and running the car on the street, I recommend the Mallory MBI Breakerless Distributor with Vacuum Pod and a Good Hi-Voltage Coil. The distributor has the small cap and works singular with or without a CD Module. If it's a strip only toy then you will only need the mechanical advance model without the Vacuum Canister.
1 - 2 of 2 Posts
