1 - 8 of 8 Posts
Re: Just installed freeze plugs......why are they wet around the edge?????
We always use a sealer .... good old Indian Head gasket shellac. Yours will probably stop after they build up some rust. You could run some block sealer or stop leak for a few days too, that should seal them up.
Yup. It'll never be easier than it is right now.
The engine is still on the stand and hasn't been fired. Do you think it would be smart to pull them out and put in new ones with sealer??? Thanks!
Did you fill the block on the stand to test or is this moisture from something else?
1 - 8 of 8 Posts
