i recently gutted my camaro putting in al the goodies and put new cam and heads and intake on along with fuel pump and carb.now when i go to crank it up it acts like it doesnt want to turn over i beleive it is electrical. now my dad beleives it has some thing to do with the neutral safety switch if anyone else has had this problem please let me know how to fix it so i can crank it up!
thank you,
Doug Hopkins
is the battery dead? did you hook all the ground wires back up? does it turn over at all? if it turns slowly, it can't be the neutral safety switch. if it does nothing, it might be the neutral safety switch.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
Ign. timing? Valve timing? (timing chain gears aligned correctly) Valves adjusted way to tight? Dead battery? All possibilities..
