My key switch has locked up and won't return to the full off position. I can still get my key in and out. How do you change out the key switch? Do I have to remove the steering wheel and internals?
I assume that you have a standard (non-adjustable) steering column. The following links to a paper and a series of drawings that describes removing and replacing the lock cylinder.
http://jimshea.corvettefaq.com/wp-content/uploads/2006/01/StdColumnD&R108JL05.doc
http://jimshea.corvettefaq.com/wp-content/uploads/2006/01/StdColumnACarDisassemblyPage1.doc
BTW, if you have a tilt column, two similar papers for that type column can be found at the same websight.
http://jimshea.corvettefaq.com/?page_id=5
