Hey all need a little advice. Did a power disc brake conversion on my 68. Got the kit from Matt's and was made by The Right Stuff. Anyway after bleeding the system found a leak under the rubber plug on the front of the valve. I tightened the nut on the front and had no affect still leaks. Found some other posts on this but I want to fix this without removing and replacing and bleeding all over again. Any help would be great. Thanks:beers:
Not trying to juryrig it just wondering if anyone has had this problem before and what they did to remedy it.
Have them replace the valve. Awhile back a large batch of those Chinese prop valves had leaks in front just like yours. They used the wrong "gasket" material and they all leaked.
