1 - 20 of 22 Posts
I was looking around Ebay for a used 4bbl, 390 CFM carb for my 250 and saw prices all over the map. I've rebuilt my 1 bbl without much trouble and know I can handle rebuilding a 4 bbl if I have good instructions (which aren't hard to find) so I'm not worried about that. Rebuild kits are about $50 so I'm fine finding a used carb that needs TLC and rebuilding it if the price is right.
So... why the massive price differences?
For instance I just found this: http://www.ebay.com/itm/4-BARREL-650-CFM-HOLLY-CARBURETOR-/191312101007?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2c8b16fe8f&vxp=mtr
Yeah it's a 650, not a 390. But if I rebuilt it myself can I change the jets to make it squirt less and work with my 250? For $56 shipped would it be worth a try? Is there any reason NOT to put a 650 on a 250 with a Clifford intake, headers and 2.5" exhaust?
What about this: http://www.ebay.com/itm/Vintage-Holly-600-CFM-Carburetor-Ford-1850-3-List-2867-/171441319886?pt=Vintage_Car_Truck_Parts_Accessories&hash=item27eab2efce&vxp=mtr
Same questions but even cheaper.
Here's a 390 CFM Holley for a few dollars more: http://www.ebay.com/itm/Holley-390-CFM-Carb-Carburetor-8007-Vacuum-Secondaries-Street-Strip-4-Cyl-V6-V8-/390924393769?pt=Motors_Car_Truck_Parts_Accessories&hash=item5b04e8dd29&vxp=mtr
Not know enough about carbs I'm leaning towards something like this. Yeah/nay?
Give me a computer, a fuel rail, and some squirters and I can work with you but these old metal boxes with floats just confuse me...
Discussion Starter #2
Also electric vs. mechanical choke? My old stock exhaust manifold had a mechanical choke on it (spring attached to a rod). What would be required to do an electric choke? If I went to a mechanical choke what the heck to I connect it to now that I have aftermarket headers?
I would go for the Holley 390 cfm you posted the eBay link to. It's a good deal as new they sell for $450
Send the seller a pm and offer maybe 200 shipped.
The 600 is just too big to make work. It's not the jet size. It's the cfm. You won't get the velocity needed for it to work.
All you need is 12v switched for the electric choke. 5 minute job. Best way to go.
Agree with John. You want the electric choke and the 390 will have smaller barrels than the 600/650. This means better response on the small cube motor. The stock 1bbl carb for that engine was probably 200CFM or less. Can't wait to see you get this 6 going!
Lyle 1969 Camaro Convertible
I agree with the recommendation to go with a Holley 390 CFM carb, that would seem a very good fit for your needs.
Another alternative is a Quadrajet. Although it is a 750, it has small primary bores for good low speed tuning, and the top plate on the secondaries can be tuned to restrict the airflow to just what the engine needs by simply adjusting the spring tension. This is not unique to the Q-Jet, but it is one example of a carb that you can do this on.
I was looking around Ebay ...
Supply and demand is some of it. A 390 is a small cfm carb and not in much demand, but those that need a 390 have to fight for the few that were made. The condition is the other deciding factor; at least if you exclude those deluded individuals that have no idea as to the value of items).
You can not change the main jets to reduce the flow of air through the carb. It is fixed by the size of the venture cast into the main body. If you reduced the amount of gas flowing through the carb it would run lean and it will either over heat your motor or put it into detonation breaking the pistons. A 650 is designed for a 350 V8 and is too big for a 250 L6.
As to the price I buy 650 cfm 4160 series carbs for $25 at every swap meet I attend. Add shipping and it is definitely not worth the price.
Same answer with the added problem of a Ford carb not having the linkage on the passenger side of the carb to actuate your transmission kick down linkage if you had a PowerGlide or TH400 tranny.
A Holley 390 cfm four barrel was made specifically for six cylinders and VW four bangers that are raced as gassers.
Actually I have been a Holley aficionado ever since GM abandoned Carter AVS carbs back in 1963. However for a six cylinder motor I have to agree that EFI is a much better solution. This is because of fuel distribution issues caused by the long log manifold with a centrally located carb. To optimize your motor you need an aftermarket Offenhauser three one barrel carburetor manifold and three one barrel Rochester carburetors off of a four one barrel Corvair flat six. Then you would have to make your own linkage to actuate the three carbs.
This would still be easier than trying to adapt the EFI off of a newer "Atlas" in line 250 cube six cylinder engine out of a new Chevy SUV or van. The easiest solution of course would be to just pull the complete motor and computer with the factory EFI wiring out of a new Chevy and stick it into your Camaro. Definitely be unique at a car show. Probably cheaper also since the in-line engine is unloved and as such cheap in bone yards.
A turbocharged Atlas six cylinder DOHC motor in a Camaro
The DOHC with covers removed:
Larger Dave aka Big Dave every where else
Discussion Starter #8
12V switched to what?
Does the carb have a delay built into it where it shuts off the choke after so much time? I'm not sure I understand how the electric choke works.
Discussion Starter #9
Thank you!
The carburetor sizing calculators are saying about 350 CFM so I'm sure a 390 would work well with the Clifford intake.
Next question: If I'm going to increase the intake and exhaust valve diameters, smooth out the ports and add a larger intake would that change the sizing of the carb?
Head work is a good idea. But the six cylinder head has a lot of work beyond just larger valves to even begin to make the same power. To achieve that goal you have to actually go to a V8 head which of course isn't offered anywhere so you have to make your own (they are made by others and offered for sale but they are not cheap).
I suggest you read Leo Santucci's book on hot rodding the six cylinder motor to learn more about this subject.
Chevrolet Inline Six-Cylinder Power Manual: Leo Santucci: 9781931128155: Amazon.com: Books.
Big Dave
Discussion Starter #11
Thanks, Dave, but I want to stick with the born-with drivetrain. I know it will never be a monster but it will be good enough to cruise and enjoy.
As to the intake manifolds: I've been looking into it quite a bit and from what I've read and seen online there isn't really an advantage to going with (3) 1bbl carbs vs (1) 4bbl. The heads on these engines are weird. I had a long talk with Tom Langdon about it when I bought the headers. I was going to make a custom intake manifold with my neighbor, inject fuel right before each intake port, and put a GM throttle body up front to control it. Turns out GM tried this for about a decade and could never get it to work right. Tom was part of that team. Everything I suggested GM already tried and showed it wouldn't work.
It's the damn siamese ports on the head that's the problem. Unfortunately there's no way to fix it short of dropping $2,000+ and, well, it's a 6, not a V12.
Tom said a single 4bbl works best. His experience with the L6 is pretty darn deep.
...even though I'm not blazing a new trail it's still fun! :D
Discussion Starter #12
Big Dave
Looks like we're racing on the replies.
As said above: I'm not looking to build a drag car. Just a fun cruiser with a bit of punch. I'd be happy around 250 rwhp. Right now I won't even put it on a dyno because I don't want to be embarrassed....
edit: already ordered the book. Should be here soon...
The choke closes when it's cold. You push the pedal one time and it sets the choke and idle stop. When you turn the key on the 12v starts heating the resistance wire/spring (think toaster) after a given time the spring unwinds and the choke is fully open. When you turn the engine off it will stay open until engine cools off.
Here's a more detailed explanation
http://www.hotrodders.com/forum/how-does-electric-choke-work-7696.html
Discussion Starter #14
Perfect! I understand completely!
You're absolutely right. That's DEFINITELY the way to go.
OK so I'm looking for a 390 CFM, electric choke carb. I want reliability and street-ability. Holley? Rochester? Demon? Any specific models?
You guys have been very, very helpful. I would have made a huge mistake if I hadn't asked here first.
12V switched to something downstream from your ignition switch so it is only hot in the ON position. The 12V applied to the choke coil causes it to expand. It expands over a period of time, say 5 minutes. During this time the choke is on, fast idle occurs and the choke butterfly slowly moves from closed to open. When you kill power to it by turning off the car the coil contracts to it's original size(after a period of time) and the cycle will start over next time you start the car.
Drawbacks- leaving key ON will result in choke being energized and may not work as intended after a period of time with a cold engine.
- Electric choke may operate when the engine is warm enough not to require it. A divorced choke activated from engine heat would not engage at that time.
The good news is Holley electric chokes are easy to adjust by loosening 3 screws and turning the choke housing.
I believe only Holley has a carb in that size now as the other use of a 390 was in oval track racing at one time, but those rules have changed. So there are only the six cylinder crowds still looking for that size carb on the market.
I also like a Holley over a Carter (Edelbrock today) as they are much easier to rebuild.
One final comment would be a Rochester QuadraJet as the small primaries can keep you cruising and even though a SBC Rochester QuadraJet is rated at 620 cfm it will never see that flow rate on a six cylinder. The Rochester QuadraJet has a variable venture secondary so it will be the perfect size for your motor since it won't flow more than the engine asks for.
With the Rochester QuadraJet you really have to get one that is off a running motor as they are a royal pain to rebuild; even for an experienced mechanic. Once properly tuned (running) they are good for over 100,000 trouble free miles.
Larger Dave
You already found it. The choke is shown in the 3rd pic
Have you thought about a 2bbl Holley? Can't beat the price on a refurbished 350 cfm with choke.
http://www.ebay.com/itm/Holley-6855-2-350cfm-rebuilt-2bbl-Universal-Chevy-Ford-Dodge-/261577900155
If not I'd recommend something like this even though it's more expensive over the same thing "used and untested" that may need more than a rebuild kit...
http://www.ebay.com/itm/Holley-0-8007-390CFM-4bbl-Carb-Electric-Choke-Vacuum-Secondary-/281289234665?pt=Motors_Car_Truck_Parts_Accessories&hash=item417e2518e9&vxp=mtr
You can also contact the Holley folks and ask about a refurbished 390 instead of new and that might save you some money.
Discussion Starter #20
^all good thoughts too. Hadn't much considered the 2bbl. I know Webber also makes one but they use that funky square air filter and, well, I don't like the looks of it. My engine bay looks as good as the body and interior so I want to keep it going that way.
What would be the advantage/disadvantage of 2BBL's vs 4? I didn't know Holley made a 2bbl that size. It's actually a better fit according to the online calculators. At 100% volumetric efficiency I require 434 CFM. 360 CFM matches up to 83% efficiency which is right in line with what I'm expecting I'll need once the head has been worked and I have a bigger intake manifold.
Here's a good pic showing the intake manifold differences. The top one is stock. Left is stock with a 2bbl adapter (which is bad). Other two are Cliffords with a 4bbl and a 2bbl flange.
1 - 20 of 22 Posts
