1 - 20 of 21 Posts
Lee-Marinette, Wisconsin 69 Camaro X 11
This has probably been posted before but my search doesn't seem to be working. I have a 69 Camaro and would like to brighten up my tail lights, I have upgraded my wiring to AAA upgrade kit. Would I have to do something else to put LED bulbs in? If a kit is needed, what kit do I need? Subsequential is not out, but need kit numbers there to and which are the best out there.
Did you just get the bulbs (front and rear) or did you get the flasher too?
You will need an LED flasher.
Don
Save some time and headache....just bite the bullet and get the LED replacement lenses. Ssssooooo much better, and safer too (they are BRIGHT)
And yes, you'll need an LED flasher...two of them, as our 1st gens (at least my 67) has a flasher that operates from the turn signal stalk, and a second one for the 4 way emergency flasher knob. The turn signal flasher is at the fuse box, and the 4 way emergency flasher is under the dash, between the left of the radio, and to the right of the steering column (held against the inner dash with a clip).
LED's use much less current to operate, and the flasher is expecting a filiment (more current), so with the stock flashers and LED bulbs, the LED bulbs with flash rapidly.
check E Bay
United Pacific 110108-09 1969 Chevrolet Camaro LED Sequential Tail Light Set
Be the first to write a review.
Item Information
Condition:
New
Compatibility:
See compatible vehicles
Quantity:
Error icon
Last one / 2 sold
Price:
US $281.99
X2 on United Pacific 110108-09 1969 Chevrolet Camaro LED Sequential Tail Light Set
shop around different prices everywhere plug and play
Discussion Starter #13 (Edited)
Thank you for all your replies, is there some bulbs better than another for the front part/turn lights?
Discussion Starter #14
Bill on the United Pacific I recieved today it says you have to run a wire from brake switch to the yellow wire on lights, did you have to do this? Also, sent me a no load flasher, does that go to flasher in fuse block or by radio?
Thanks again for the suggestion, on the United Pacific, picked them up on offer.
I did not run the wire and it works fine and I found the same with the flasher worked with the old one but changed it
Discussion Starter #16
Bill, which flasher, fuse box or the one by the radio?
You’d need to change both
Using LED taillights I didn't get any special flasher/relay....stock one was fine.
Discussion Starter #20 (Edited)
I want to Thank bills69 for all the help and info, and the others that gave info
1 - 20 of 21 Posts
