1 - 8 of 8 Posts
1968 Camaro 454 LS6, Holley 950, Tremec 5 speed, Currie 9 in
I rewired my 68 with a Painless wiring harness. I have had an issue for weeks now trying to figure out why my hazard lights worked fine but my turn signal lights would not come on at all. I have Digi-tails tail lamps and front turn signals that all worked fine before rewiring. After many hours, testing, rewiring and at times driven to drink, I finally figured it out. The short version is the LED relays have a B and an L on them. The power coming out of the fuse panel was going to the Load side. I switched the wires and all works now! A small but annoying issue solved.
I assume you're talking about the flashers when you mention relay? I bought some flashers a while back that had an adapter that switched the polarity. I like switching the wires like you did so the flasher doesn't stick out so much.
Your problem reminds of one I had soon after taking my 69 out for its shakedown cruise. The LED T/S's would not work if the park lights were on. What was strange is that the dash indicators worked properly. They are wired directly to the front T/S's. I still don't know how that symptom is possible. I immediately thought of the grounds as bad grounds like to produce weird symptoms.
Unfortunately, they started working on their own. Have no idea what fixed it. Now, I try to watch the T/S's reflection in the car ahead of me.
Sorry for the hijack...
I had a similar issue. Same setup. Switched the wires up front and all well. Those Digitail items are nice, but the instructions suck.
Discussion Starter · #5 ·
I left a message for Digi-tails to call me, never heard back. I bought two Painless LED flashers. It worked great for the hazard 4 ways, but not for the turn signals until I switched the wire. Not sure if that means the Painless fuse panel and wiring harness were made wrong? All good now!
I remember my Classic Update harness for my 66 C10 needed the polarity adapter. The 69 Camaro I did before that and my personal 69 didn't need it. I look for the polarity so I can just swap polarity before the final install.
My hazards do not work, but everything else is good. I used the AAW wiring kit and also two of the Digitails flasher units.
Discussion Starter · #8 ·
Try making two short wire leads and reverse the order of the two wires at the fuse box for the hazard/flasher unit.. They should work. If they do, open up the fuse block and switch the wires. That's what worked for me.
1 - 8 of 8 Posts
