68 RS/SS Convertible
MY 68 has a stock tach. The engine has a delco-remy dist. The RPMs shown on the tach are too high. Someone suggested to me there is an electronic part that will even out the signal so the tach is correct. What is that magic part called?
Thanks,
278584
Reactions: 68_Red_Cnv
Just want to mention that your distributor is typically known as an HEI distributor (High Energy Ignition) Most guys would not have a clue if you you said you had a Delco Remy distributor :)
