I searched through both the Chilton's and Hayne's, Camaro Manuals and can not find the location of the Fual Pump Relay, I purchased the replacement relay and know that it is located in the engine compartment on the Left side Firewall. I thought that I could use the pat number on the relay as a locator. But all three relays in that area of the fire wall have the same part number stamped on them. Can you Help me to locate the proper relay?
Thanks for the help
Welcome to the Club!!!!
You might start by marking the new relay, so it won't get lost.
Replace a relay one at a time, until the fuel pump comes on. Bingo! you've located the f/p relay.
Many GM cars have a fuse mounted at the fuel pump relay, this is a good way to distinguish it from the other relays that are usually mounted next to them. Like Everett said most of the relays are all a common part number and can be swapped. so you can probably just start plugging it in until you find the right one, verify the part numbers are the same first.
Dave
