1 - 14 of 14 Posts
George, 1st gen Camaros did not come with a steel wheel (not a rally) in 15x7 or 15x8 rim. The 15x7 rallys are common on mid 70 Monte Carlos, but I am not sure is the base rims were 15x7. Best bet is to look for station wagon wheels from the 70s. But the offset might not be what you are looking for. 15x8 are Corvette rim sizes and their offsets were a little different. Good luck!
Here is the chart on Factory 1st gen wheels http://www.camaros.org/suspen.shtml#Wheels
George,
If you are referring to Rally Wheels, the "FW" coded Rally is a 15x7 with 4.25 backspace. They are available at swap meets and on eBay, but be aware that their condition could be mis-represented. I bought a set of two and ended up with one bent one. As far as 15x8s, the "AZ" Rally from 69-82 Corvette has a 4" backspace.
Discussion Starter #9 (Edited)
5 x 4 3/4....5 lug on a 4.750 circle.
What disappeared...:confused:
MY Thread I had to go looking for it
Thanks Garth came up with these summit part no: WVI-62-5734044 and WVI-62-5834044
Hay Garth where is I 5 ?
68 RS L30 AA 749
hmm, I don't see a 15x8, 4.5 bs. With 4.25bs, you're a little more limited on tire width.
What year Camaro and tire size are you thinking ?
68 RS L30 AA 749
:thumbsup:...hard to beat that look, George ! A guy really needs about 2 or 3 different sets of wheels & tires, depending on the mood or occasion.:D
1 - 14 of 14 Posts
