I will very soon have a new engine for my 68. The only problem is that the engine is factory painted industrial black. When it comes, I want to paint it bright Hi-Gloss orange. What would be the best brand paint to search for and from where? Any suggestions?
Chasing a dream one bolt at a time
I have had good luck with Plasticoat, nice chevy orange, glossy and lasts pretty well. I get it from Advance Auto.
good luck,
Joe
I like Plasticoat too. The paint seems thicker than Krylon.
Here's another vote for Plasticoat, they also make clear so you can add gloss if you want. It holds up great and can be touched up without a problem. I wouldn't recommend Duplicolor, it looks ok, but you have only one shot at it. If you try to touch up or add a second coat it will wrinkle. Just a heads up.
Royce
70 Camaro 385ci
69 Camaro (soon to be 6" rod 355 backed by a T56)
2000 GMC Z71
http://hobbystage.net/camaro/camaroman7d/
I've had good luck with diplicolor. Its supposed to have ceramic in it. (go figure that one). But hasnt discolored on the motor and their clear stays clear. Got it at napa.
Black 69 camaro
Here's another vote for the Duplicolor.
They have a version that is heat resistant up to 1200 degrees F. It will rinkle if you lay it on too thick, or if you don't wait long enough to spray your second coat. I've used it on 14 engines, and have had excellent results.
Another tip. If you want to paint your engine a color that Duplicolor doesn't make, find one that they do make that is close, and lay it on good, about two coats, then scuff it with a gray scotch brite pad lightly, then spray on your color of choice, again, about two coats, and then you have an engine painted any color that you want. This works very well for anyone that wants to paint their engine the same color as the body, or trim.
Hope this helps!
I know some here don't like it but I have had great luck with the POR-15 engine paint kit. Very glossy. Bright orange! Just brush it on. No brush marks. Probably want to use some spray paint on the pan though.
I get a lot of great comments on my engine bay. I have digital pics if you want me to e-mail them to you. Let me know.
KEl
North Texas Camaro Club
Is the glass half empty or half full???.....Neither, the glass is twice as large as it needs to be!
VHT on the outside, General Electric Glyptal on all the inside non machined surfaces. I have used both for many years.
