I have had these Sub Frame Connectors and I have tried twice to install them. The first time I could not get the leaf spring pocket bolts to come loose due to Nut clips broke so I gave up. Last week after I installed my new leaf springs along with all new pocket bolts/nuts I thought I would try again.
I jacked up the body enough that with the pocket bolts loose, the leaf spring was separating from the body, but I didn't separate too far because I was afraid that the leaf spring would move sideways or forward/backwards to the point that I might not get the bolts back into the nut clips. Also, these new front leaf spring pockets I bought have a tab that goes up into the body to help locate the pocket, but this tab prevents the connector from sliding back into place. This is why I cut a slot into one connector thinking that would get the connector into position, but it still would not go. I'm thinking it was because I don't think I had enough separation.
I think I understand that in order to get these to mount, I will need to also loosen the rear bolt in the sub frame and raise that part of the body to separate them enough so that I can place the connector into both areas at the same time. I just want to feel safe that I won't loose positioning of the current features when I take one side loose enough to really get an opening to be able to place this connector into position.
Thanks,
Brett......
Thanks,
Brett......
