How much will this project cost me?
should I restore the exterior and interior 1st? How much will it cost to get rid of rust? I want a pro to do all the body/paint/interior
or should I build the drivetrain 1st? I can do this. crate? or piece together?
How much is a good amount of $ to start with.
I'm currently restoring a 67 Camaro.
Started with restoring suspension, brakes, rear end, bearings. Then moving on to engine, trans. I'll then sand her down, have it professionally painted while the engine is out. Then LAST comes the interior. Don't want to get overspray or screw up interior with a screw driver in my back pocket while doing all the other stuff.
Here's what she looks like right now.
http://www.fbody.com/members/2001RagTop/Best67.jpg
Bought her for $2,500.00 and so far I have about an additional $1,500.00 in her without touching engine (runs fine for now).
Oh, all new weather stripping goes on last.
She's currently up in the air getting new rear axle bearings and have all the parts for all new rear brakes. A sandblast cabinet is real useful for taking off the rust on brake backing plates, drums and other assorted parts.
Randy
1967 RS M3 with original 327
2001 Black Z28 Convertible
[This message has been edited by 67RSM3 (edited 03-28-2002).]
looks pretty good from the picture, if the paint is in bad shape and the picture hids it, well then there is a good place to start, you can get rid of any starting rust problems in the process.
That's really a relative question. It depends on what the car needs. If it has quite a bit of rust and needs an engine and trans rebuild, $10,000 probably won't get it done. On the other hand, if the rust is very minor and the motor is sound with no other major problems, you might be in the ballpark.
in the restoration/tech section of this site, accessible from the main page at www.camaros.net , there is a good article about restoring a car and all of the troubles and extra costs you may run into. Might want to check it out.
