I am currently having fuel gauge problems and I hope you will be able to help me. I have replaced my fuel tank, fuel lines, and sending unit (It is all Brand new). The low fuel light stayed on and the tank reads over full ( past the full mark ) until I started to take apart the Low Fuel Warning Module. Now the fuel gauge reads full (same as before) and the low fuel warning lamp is off (light is off). The gas tank is full with about 45 miles driven after the fill up and no change in the measurement on the gauge. I was in a rush to put it together and probably did not clean the surface for the ground wire as good as I could have. Do you know the values for the components so I can replace them all with parts from a local electronic parts store. ( $50.00USD is a little steep for me to have to replace the whole unit). If I replace these parts and clean up the ground will it fix my problems? A board schematic would be cool if it possible to get Any help or advice would greatly be appreciated.
1968 RS/SS 454 TH400 Black Deluxe Interior
http://www.telusplanet.net/public/jgrock/1try.htm
