Had a problem with an old voltage regulator which was always charging at around 15.5 to 16 volts. Replaced it with a Wells regulator. It was charging around 13.5 to 14 volts. Today after taking the car out I see that I'm around 11 volts according to my gauges. I had the battery checked out just before I changed regulators and was told it was OK. Isn't 11 below the minimum??
Discussion Starter #2
Come on now someone has to have an opinion here, help me out..Please.
Not necessarily, if your battery is fully charged, there is no real need for full voltage to go out of the regulator. Put your lights on and run it.. see if the voltage comes up to compensate.
Where does your voltmeter sense voltage? Voltmeter should always read above 12V even if the battery is fully charged and there is no current draw. 11 Volts is too low. Of course if your sensing point is far enough from the Regulator, the battery may be seing 12+ Volts and the gauge could still be seeing 11. Somethings not right.
Thanks for your help, I checked everything again and really no change, but happened to check the connections on the regulator itself and found a loose connection. Thanks everyone for the help..
What started this was I had changed regulators to a Wells transistorized which was working great. Then while traveling with about 40 other cars to a car show everything just quit as far as electrical currant to the engine. Checked everything and found a loose nut on the coil. Then the low voltage. Everything seems ok now. Good reason to always check connections as they will lossen at times.
Find out where the voltage drop is. Measure from battery post to clamp. Then measure from the clamp to the junction block behind the battery. Then measure from the post to the horn relay. Lastly measure from the post to the B+ terminal on the back of the regulator.
Does the battery charge normally on a charger? New batteries can be bad. Also, bad regulators or alternators can undercharge a battery and make it go bad as well. If the voltage drops look good, then the connections are good. One or more of these things are causing the problem - 1) Battery 2) Alternator 3) Regulator or 4) Bad Connection.
BTW: Weekends aren't very active on this site. I guess we are either working on our cars or driving them.
