On my top perch that is attached to axle housing the bolts that secure the bottom plate (shock mount) don't have heads on them. They would appear to be pressed in the perch as I just used a socket/ratchet to remove the bottom nuts to remove the lower plate without the bolts moving at all. The "bolts" remained in the top perch plate.
Also the holes for those bolts, assuming the bolts can be knocked out, are wider spaced than what a U bolt over axle would line up with. I would have to drill holes in upper perch and bottom plate to use U bolts
I will look again but I just installed sub frame connectors and had the lower plate off when dropping the leaf spring and the spacing of the holes is wider than the width of axle housing tube
My thought is if the bolts can be knocked out I would just get 2" longer ones and sandwich the spacer between the perch/leaf spring/bottom plate
Am I seeing all this right or??
I would also keep the rubber on both sides of the leaf spring
