You should get the following from KEISLER:
1. Keisler Super Duty reproduction 621 bellhousing for LS ENGINE, with bellhousing mounting hardware, $249
2. pilot bearing for LS engine, $39
3. PerfectFit Hydraulic Clutch Actuator kit for MUNCIE M20/M21/M22 with everything needed for a perfect, no cutting fit, all premium parts, no circle track or plastic junk, $649; get the Ring Bros reservoir for the killer look.
I can add pics and links if needed.
