Build 413 ci ls3( ls1 24 reluctor crank) engine starts great when cold or warm. Take it
out for a good 25 to 30 minute run and it won’t restart. The starter just clicks very lightly.
Its a cheap eBay starter. It turns the motor over well, not a compression issue. Just at full engine temp nothing. I am using stock gm 69 camaro small battery cables. It’s wired correctly not burnt wires or anything. Do I need just pony up buy msd starter or something equal?
Double check your connections before you buy another starter. I had that issue, wound up being the cut off switch on the battery had corroded internally. Unfortunately, I bought another starter first.
Don't know whether this will help with your situation but I'm going to add this heat shield on my car even though I don't have a starting problem using the factory starter.
I went thru 3 ac delcos on my LS that stupid plug..but I bought a "clockable" starter made in USA from power Master no plug to jam up and crack by the block and better connectors. It spins faster and no more issues for mine..
