There was never an LS7 in a Corvette - it was cancelled three months before model change. It WAS available over-the-counter, though, and that's where they went. The 5-quart LS7 pan (which was used in 1965-74 big-block Corvettes) won't fit in a Camaro, as the sump is longer and interferes with the rear of the front crossmember. You need the 4-quart LS6 pan, P/N 14081027 - it has a shorter sump and won't accept the LS7 windage tray. There are lots of other aftermarket pans that will fit (Moroso, Milodon, Hamburger, etc.), but they're more expensive.
JohnZ
CRG
'69 Z28 Fathom Green
