Factory installed m-20 transmissions were installed on car's that had rear gear ratio's of 3.73 and higher (numeratically lower,3.55,3.08 etc.) Lower rear gear ratio cars got the m-21.
Discussion Starter · #3 ·
I am already aware that M-20s were mated up to any gear 3.73 and higher. I just want to know what the standard rear gear was with a M-20.
Thx
Thx
Your question doesn't make any sense.
The transmission alone does not determine rear ratio.
If you can find a 69 power team chart, and know the engine, transmission, AC or not, and RS or not, you can determine the standard, economy, performance, and special ratios available.
You also might get a better response in the transmission and driveline section
