W
Guest
Has anybody ever put 28x10.50 ET Drag tires on a 2nd gen? Is there a clearance problem? Thanks.
1973 Camaro RS LT
355 CID
Summit 4340 Steel Crank
Summit Pro-Line 4340 Steel Rods
TRW Forged Steel Pistons, 8.75:1
Dart Sportsman II Heads
Crower Beast Cam
CompCams Roller Rockers 1.6:1
Edelbrock Perfromer RPM Intake
Holley 750 Double Pumper
4.11:1 Posi
Welded Subframe Connectors
I run GY 29:ers without probs bro.Tend to grow somewhat after use,but still no probs.(The widh that is).Note.My GY are so called stick ones.Ie;they are done with a harder sidewall.Dunno if it affects anything,but....
BTW.I like the weatherman tag
DVC-98.Racing
482 cubes of fogger injected thunder in a 71 z.
[email protected]
W
Guest
Hhhe, can you beleive someone stole Chevyman!!??!! Anyway, what kind of rear shocks are you running? I asked because we used to get 26 inch BFGs to touch the inside of the fender. It would actually cut the sidewall of the tire. We had new leafs installed and put on air shocks. If we keep the shocks up, they won't rub. Just kind of scared of the 2 inch jump.
I'm gonna find out about this Chevyman imposter! He hasn't even posted yet!!
1973 Camaro RS LT
355 CID
Crower Beast Cam
4.11:1 Posi
I run have run 29x10.5's in the past, but they were actually circle track tires. ( Got a dirt track near your house? I used to get all my tires from those guys for free, worked great. I am the chepest git you will ever meet.) Oh yeah, you don't really have STEEL pistons, do ya?
W
Guest
Yes, I do. The motor is set up for a blower. I am sure that they are not pure steel, just an alloy containing mainly steel.
Yes, I have a couple of dirt tracks around. I'll check into it. Thanks.
1973 Camaro RS LT
355 CID
Crower Beast Cam
4.11:1 Posi
