Can you guys tell me if an M20 transmission is compatible with an LS1? If so, what extras or modifications would need to be made. I have to imagine if you can bolt a T-56 trans to an older GM block that you can do the vice/versa and bolt an older transmission to the newer block. Any help you can offer would be great.
Thanks!
Tony
Discussion Starter · #3 ·
Justin...I don't know much about manual transmissions. I read the description in the add. How can you tell it's for a Muncie/T10 bolt pattern?
Thanks!
