I am in the process of installing the MAD electric "new system". I have one of Mark's terminal blocks mounted to the firewall and one on the radiator support. I am no longer using the horn relay as a buss bar. The horn relay will be used just to operate the horn and the key buzzer. Can I just run a wire from the MAD terminal block to the left post of the horn relay to power the horns? If so what gauge wire should I be using?
Discussion Starter · #3 ·
welll. that's the problem. I bought the kit about a year ago and must have misplaced the manual that deals with this. I did read everything 2 or three times when I did get it however, so most of the wiring I remember or have written down. This part i dont' remember.I have been trying to call Mark but to no avail- It's either busy or just rings
Manual is here
http://69camaro.nextmill.net/temp/Mad_RelayKit.pdf
And yes I did the same, just ran a 12 gauge from the terminal to the horn relay to power that relay. On my Nova though I am going to run a separate relay kit so that I don't have the large old school relay taking up space.
