1 - 2 of 2 Posts
Help I have no spark from my coil. I have power to my coil from the ballast resistor and a slight flicker from the wire coming from my dist, but no spark. Do I have a bad coil or a dist. problem?
Are you runnin' a Unilite?? The test light should go solidly on and off as the module switches. If that's not the case, I'd suspect the ignition module. Unilite's are notorious for burning modules. I think that MAllory will replace them with a redesigned unit in some cases??
1 - 2 of 2 Posts
