Trying to get a accurate vacuum reading to set up holley carb (4053) on 69 Z/28 Camaro.Was using port on base plate(timeing port),then was told to plug into port were secondarys are hooked up too,then watched holley video and they were taking vacuum right from manifold.
Having power valve issue's and trying to figure out best size,had a 8.5 which was to large.
Randy
Find a port on the base of the carb that at idle has constant vacuum this is manifold vacuum, ported vacuum is still on the base of the carb but only pushes vacuum at higher rpm's.
Once again thank you,
out of curiosity does anyone know what size their running for their power valve for a stock 302 witha 4053 holley.I know cam as well as other factors play a large role.
