It's a manual gear box lube that I know Rick's sells. It's GM stuff so I also would think a good auto parts store or a GM dealer would have it.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips.
It is not oil, but grease, like you would use to lube the chassis. Take out the bolt that says "check oil" and the one at the very top of the cover and get a hand grease gun, put some good moly based chassis grease in it and pump it in until in comes out of the "check oil" hole and reinstall the bolts that you removed. Hope this helps.
Leo Paugh
MCC #017
www.clark.net/pub/chevelle/mcc.htm
If you have no fear, you're not going as fast as you could.
