Did you like the way it steers with the ratio you have?
The SS used a much faster 4 to 1 in 1969 then the standard Camaro which was horrible (like 6 to 1) IMO. When I was young it was ok but certainly would not want either now. My wife complains about how slow her 71 Camaro SS with PS is with 3.2 to 1 but then again her daily is a 2015 Mustang GT. If it were me and you are not looking for that extra couple HP I would skip the manual and go with a 2.8 PS ratio of used in my 74 Z28. Your arms will appreciate it and it will drive like a totally different car. Then add some Caster and you will love it.need a new manual steering box for a 72 ss where and what type/brand /where to buy ?
do not know the ratio of the one I have guessing it is original maybe 16:1
should I go a different ratio ?
Agreed, I would like to add that the old thinking of power steering robbing power is misleading. You could probably measure a few HP loss but it's only a "negligible amount" (less than noticeable) and mostly when turning.f it were me and you are not looking for that extra couple HP I would skip the manual and go with a 2.8 PS ratio of used in my 74 Z28. Your arms will appreciate it and it will drive like a totally different car. Then add some Caster and you will love it.
It really only takes power when turning and ever then its peanuts. It's pretty simple to install just requiring a new box, rag joint, pitman arm, 2 hoses and the PS assembly. Afternoon job at most with the only gotcha being the brackets if you have a 8 inch harmonic balancer and even then you just need the right brackets and even that may not be necessary anymore but check. How do I put this nicely, Manual Steering Sucks.....next you will want ACAgreed, I would like to add that the old thinking of power steering robbing power is misleading. You could probably measure a few HP loss but it's only a "negligible amount" (less than noticeable) and mostly when turning.
