1968 Camaro Convertible 250 to a LS3 Engine Swap
I'm very confused, have a young guy at work that seems to have a lot of knowledge about engines?
He is indicating that I only will want to use one of the three sensors?
The following are pictures of what I have:
A MAT Sensor that I have tapped a hole into my Air Intake Tube.
A MAP Sensor that I purchased an short adapter cable to connect to the Terminator X harness.
And finally the blue vacuum line coming off the back of the Terminator X box.
Before talking to him my expectation was that I was going to use both the MAP and MAT sensor and then disable the MAP Vacuum within the programming interface?
Any help with a better understanding of how these play together is greatly apprciated.
MAT/Intake Air Temp and MAP/Manifold Air Pressure are 2 completely different sensors. Use them both.
I have no ideas about the MAP vacuum tube.
Stop listening to the guy at work. He doesn’t have any idea what he is talking about imho...
Don
Reactions: Vega$69
Thanks John & Don.
He is a pretty smart kid and when I showed him the pictures he agreed, I think yesterday he though I was describing some other type of sensor that runs off the intake tube?
