1 - 2 of 2 Posts
I have a March serpintine set up and am having problems when I drive and the car heats up the stearing gets hard.Has anyone experienced this.The pump is a 87 sunbird and the rack is a 87 thunderbird and the pressures need to match has any one had any experience with this. Thanks in advance.
Discussion Starter #2
I found the problem this week and it is fixed now. I bought a pressure reducing kit and it required two washers I thought I only put one but there were two.When I took it apart the check valve was sticking iI cleaned it put three washers on it and it was fine but not real easy to steer so I went back with two washers.I think it may have just been rubber from the an hose cuts I made.This is if anyone ever has this problem....
1 - 2 of 2 Posts
