Finally was able to get my 1stgen Camaro on the ground again to put her on the lift to take some under view pics.
All the fab work was done by me at my shop.
The Torque arm itself was copied after TCI's kit but with some changes.
Rear suspension is specifically designed for time attack/drift use.
The subframe is not in quite yet. I gotta do some more upper structural to the car before I start lower structural due to chassis deflection. But the sub frames will be built out of tubing, welded on the outer link mounts-frame then running into the front torque link pivot tube centered between pivot and frame.
Looks great :beers:
Torque arm crossmember might be a bear when/if trans gets removed ?
