Ok Im lost this is a new build that I just drove for the first time.I used wilwood brakes front and rear and a new disc brake master from ccp. When I run the car brake fluid comes out the top of the master, I have tightened the bails to hold the cover tighter but it still does this , what should I try next ?
Re: master cylinder leaking ?
First I would make sure my gasket is good or my cap is straight. I have seen new ones leak or not fit well, Second I would make sure my fluid level is down about 1/4" from the highest point from the top .
You did not say which m/c you had, tall or short. ?
