Hi i have a stock 69 Camaro with drum brakes and I'm wondering if a 18x8.5 wheel with a 2" adaptor (to correct the +56 offset) will fit without modifications. Tire size would be 245/40/18 potenza tires. Thanks!
With the 2" spacer it would put it about right. Since you said stock, I am assuming the car isn't lowered at all. That is a large spacer to run... You fitting late model wheels on the car?
