Just posted the main caps question, but have another. Again, I'm having a sbc 383 built that will be running approx 550 hp. The car will be driven primarily on week ends and will see limited if any strip time. I'm kind of a horsepower junkie, so I was thinking of going with a Summit billet electric water pump to save horsepower. I've read you can save around 20 hp by using an electric water pump. The pump flows 37 gpm and has a 10,000 hour life expectancy and draws 6.1 amps. Do you guys in the know believe this would work fine and be reliable, or should I go with a mechanicle water pump? I have a 100 amp alternator in case that's info you would need, to give me a more accurate answer. Thanks again for the help.
Jay
Jay
