hi guys i have a 69z with a bb and accel HEI dist. i am changing out my old stock starter for a mini there are only 2 termanals one 4 the battery and ignition. I called summit up they said i dont need the other wire it use to feed points on the old system . Does this sound right i grew up in the old points day hei is new to me thanks on this one not sure:confused:
Yes, that is correct. Hook up the battery cable & the crank circuit wire and you are good to go. If you still had points, they sell an adapter that goes on the crank terminal as well that provides a hookup to the coil, but is has a diode in it so the starter won't keep spinning after you let off the key from power backfeeding from the coil positive to the crank circuit on the starter...
