1 - 2 of 2 Posts
No wireing instructions and I am a dummy today. Have a ministarter/ with one terminal
other than the battery cable. Have the purple
(from ign switch)and yellow wire(from starter to coil). Where do they go on new mini starter?
Purple wire get's attached to the small terminal on the starter.
There is no "sol" connection for the yellow wire.
It provides 12 volts to the coil for starting, bypassing the resistance wire in the wiring harness to the coil.
If you have points ignition, You either have to put a relay on to energize it triggered by the purple wire or go to electronic ign.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350 Can-Am Vintage Racer
1 - 2 of 2 Posts
