1 - 16 of 16 Posts
With a 18 gal oem gas tank and my 69 with a 640hp 572 bb under the hood, range for travelling is a real problem. Does anyone know of a place I can contact in Canada, that can provide me with a much larger tank that will fit in the oem location...(don't want a feul cell in the trunk), that will work with a carb, and will work on a budget....I know that's a oxymoron...lol
Tanks Inc builds one for mini tubbed cars that is chopped off on the corners but they make it an inch deeper to get capacity back. Might be able to check with them about building a deeper standard tank for you. If the 1" deeper is the whole tank and not just the bottom portion that is worth around 800ci or 3.5 gallons. Also have to consider the sending unit pickup and straps. Plus there's really not much room to go lower with the tanks and for sure you can't go out any. You could pick up some capacity if the tank were squared off instead of contoured but it would be ugly as hell hanging out below the rear valance.
Spectra is the main supplier for OEM type tanks and they're in Canada. They do not market an extra capacity tank for the F body but you could ask them about building one. I know they make a double capacity 38 gallon rear tank for the old dual tank Ford trucks.
Well it looks like Im S.O.L for a bigger tank within my budget so I guess Im forced into looking to put an auxiliary feul cell in the trunk. Summit and Jeggs sell all sorts, and sizes, but I really would like to run my oem tank as primary and use the second feul cell to supplement it. Any one have any ideas on how I can do this? Maybe have the cell up top syphon into the oem below therefore essentially having both tanks act as one big one? ....going all mad max on this one...I knew the 572 was going to be a problem with feul economy....but damn, when u can see the needle drop as your foot does....lol
you will have to be able to control the flow from the upper tank to the lower, or you will over flow the lower.
if you are using a return fuel line that will create another problem
If you decide to run a separate extra tank or fuel cell, install an electric selector valve that controls which tank you are drawing from. If you run a return line, you'd need two valves.
The simplest way is to have a valve on the fuel cell line that feeds the OEM tank.
The issue I see if you let it siphon it will overfill the OEM and dump fuel out the filler.
With the valve in place you can re-fill the OEM by opening the valve to re-fill then closing it again. You can also leave a couple gals in the cell to use as a reserve.
You can plumb it with quick connects and remove it when not needed.
Maybe you need to "think outside the box."
1) Start your trips from high elevation and coast a lot of the way.
2) Mount a sail on the roof.
3) Remove pushrods from cylinders 2, 4, 6 and 8 and run on 4 cylinders for long trips.
Where there's a will there's a way ! :hurray: :beers:
I know exactly how you feel, I have a car with a lumpy 496 (722 hp) that needs a 50/50 mix with race gas. It doesn't get driven much lol. The gauge seems to always be half way between E and the door handle.
Discussion Starter #12
Hey guys thanx for all the help...even the funny...lol. I have an oem tank without a return line, so I don't think this will get too complicated. I like the idea of just having a valve...(manual) to open and close the upper cell to refill the oem when needed. I just now need to find a fuel cell that has its exit line at the bottom of the tank so gravity can move the fuel from top to bottom. I havnt looked into it much but most of the cells I see for sale look like they draw from the top just like the oem...hhmmmmm
Six speed trans or a tag along fuel trailer?. You don't really have any other storage capacity, as you stated in the trunk is not an option and don't blame you.
There are two small areas under the car, outside the springs , under the trunk floor but , will two or three gallons be enough?
Another idea is to use an electric pump to transfer the fuel from the fuel cell to the OEM tank. Use the top feed tank and quick connects to remove it when you don't need it. Install a fitting in the fuel neck and run the hose from the electric pump to the fitting on the filler neck.
When the cell is disconnected the open fitting will work as a vent.You can then just have a switch in the cockpit to transfer fuel on the fly.
I don't think the fuel will siphon from the cell with the pump turned off so you wouldn't need a valve with the top feed fuel cell.
I actually used to have a 55-Gal Drum as a 'spare' fuel tank in my '77 Chevy 4X4 for extra capacity when we were taking deep 4X4 trips into the desert or Mexico years ago. :thumbsup:
Since the truck already had the two (2) factory side tanks, the "Drum" gave me @90 Gals total ...
I didn't bother with any fancy switches/solenoids/valve(s) for this, just hooked a 'feed' line (with a positive Shut Off Valve in the hose line) to a 'T' in the Vent line at the filler tube, and then modified the right side tank sender/pick-up bung fitting by removing it and installing a new (solid line) 'pipe' into the removable sender base - think of it like a return line fitting, but it extended down about half of the tank depth.
Then I reassembled and routed the 'new' pipe fitting up to the 'Drum' as a "Vent" via fitting threaded and sealed into the upper area above the largest threaded bung.
I just used the larger Threaded Bung in the "Spare Drum" as my fill point - yes I had to unthread to fill, but this wasn't very often - and 'sealed' the drum back up once full again.
In operation - I filled the upper Drum, opened the lower outlet valve to feed the right tank (normally right as we left the paved/main roads and that tan was already down a bit) and as soon as that tank hit @half-full the new piping I had installed would get above the fuel level and then it allowed vent air to get to the spare drum in bed of truck and allow fuel flow into the lower tank ... viola! as the tank filled it covered the 'vent' and stopped flow for a while until fuel level dropped again and fuel would flow ... and so-on, and so-on, and so-on ... until my 55-gal drum was empty.
I would just monitor the dash fuel gauge - which would just stay @1/2 until the drum emptied - and as soon as it started to drop again I knew the 'spare drum' was empty ...
My "Range" was now really impressive :thumbsup: Seemed like we were always siphoning fuel from my rig to give others ... I once made it from L.A. to Albuquerque without stopping (okay, once to 'P' :D ) and really could have made it further, but didn't know where to get fuel next :eek:
This system worked flawlessly for years, never leaked, and required no maintenance. I had the drum strapped into bed on 'bunks' with metal banding that just unbolted when not needed to give me my whole bed back again.
I finally removed the plumbing for it about 10 years ago after many years of not going that far back offroad anymore ...
Soooo - if you can fully seal the 'spare' upper fuel cell/tank and use a vent tube that is positioned under normal upper fuel limits - you can have a tank that will 'vent' via the fuel level and not require any fancy pumps/valves or other items to transfer fuel and maintain level/flow.
The "Secret" is the 'seal' of the system :yes:
Discussion Starter #16
Instead of using a custom system to fill the oem tank that includes the filler neck , what if I just bought a return line sending unit (instead of the single line unit I have now) and use the return line as the fill tube from the cell up top? That way I don't have to modify anything other than a new hole in my trunk floor for the fill hose.
I just happen to have a spare holly blue pump handy , as Im using a manual pump presently . I could use that...(thanx Vega for the idea) to act as a transfer pump. Does anyone think using the return line off the sending unit will work? Will the oem locking feul cap vent this filling process adequately?
1 - 16 of 16 Posts
