1 - 1 of 1 Posts
Finally going to pull my beloved Hotchkis 2" drop springs for a set of Moroso drag springs. I have a set of 47150 (213 lb rate) that have 1 coil cut. They were very low on a aluminum headed sbc so doubt they will work with the BBC. Here is the car/motor
69 Camaro all steel
491 Stroker
AFR aluminum heads
Aluminum intake
Aluminum water pump
Battery re located to trunk
Anyone else with a similar set up? Would like same ride height as 2" drop coils.
1 - 1 of 1 Posts
