1 - 10 of 10 Posts
I seen somebody posted some where about some motor mounts to move the small block forward a bit in order to use a large body HEI. does anybody have part numbers?
http://www.pozziracing.com/camaro_engine.htm
Here is a link to David's information on motor mounts, but this only tells you what is supposed to be correct for a model year.
Have you tried using the small head HEI dist?
i would love to try the small hei but i am short on cash. is there a junkyard swap for this? if so what car can i pull this off of? year make model?
If you use those 327 mounts, it will bring the engine forward and your headers usually hit the steering box and if you have an 8" balancer, it will be into the swaybar. Do yourself a favor and get a small body HEI, or dent your firewall... it is not visible, unless the engine is out.
OMG ,No offence to you Tom ,but Dave DON'T DENT your firewall,use a point dist.(there a dime a dozen) or I think they make a skinny cap for your HEI ??? someone else out there that's in the know???Good luck Dave Happy Motoring
If you want the stock dist look, you can change out the internals for Petronix breakerless system.
Discussion Starter #8
Thanks does anybody have one laying around?
Discussion Starter #10
i will check out a few more yards but i may get back to you on that Don
1 - 10 of 10 Posts
