I have a BBC and want to move the alt from the driver's side to the pass side so the engine compartment has better cosmetic balance, instead of the pump and alt on the same side. I also need to install my water pump and need to know if the brackets used on the pass side incorporate the water pump bolts or not. I'd like to go all stainless if possible but I'm not sure if I'm going to have to use one of those bolts that has a stud on the end for the alt bracket or not.
Any pics you guys could post of the front of your motor would be AWESOME!!! To have it described is one thing, but to see it makes it sooooo much easier. Thanks!!!
