I just installed a msd billet dist. and a 6a ignition box. When it idles, i get a screaming noise. I think from the alternator.We i rev it to higher rpm's the noise goes away. Or could it be from the dist. drive gear? Instructions said something about to monitor gear break-in and wear pattern. Thanks,Roger
Discussion Starter #2
I had a friend listen to the noise. Sounds like a high pitch whistle coming from the dist. May be the vaccum advance can. Noise goes away when you rev the engine up. This is a brand new dist. just installed. We unhooked the vaccum line for it, but still made the noise. Any ideas? Thanks,Roger
Maybe it's sitting too deep?
You could try pulling it and checking the pattern on the gear...
MSD makes an adjustable collar for some of their distributors..
Don~ ZZ430DropTophttp://hometown.aol.com/zz430droptop67rs
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
[This message has been edited by ZZ430DropTop67RS (edited 05-03-2002).]
Might be a dry bearing for some reason. Have it spun on a distributor machine or try spinning it with a drill. - Out of the engine of course!
David
David's Motorsports page
First Gen Suspension Page
I might pull it out and look at it. I have only ran it about a half hour since installed new. This one doesn't have an adjustable collar. It is in a 71 chev 350 with an edelbrock performer rpm intake. Are there dist. spacers if i find it is in too deep? If it has a dry bearing, msd can give me a new one. Hate to have a problem with a new part, but i guess it happens. I will call the msd tech line first. Anyone else have had this problem? Thanks,Roger
I took the dist out and spun with a drill, no noise. Put it back in, and it started screaming again. Took it out and exchanged for a new one, No more problems. Must have had a lemon from the factory.
