1 - 2 of 2 Posts
Hi guys, I have a new HEI distributor. I'm looking to also add an MSD box (6AL). My question is, if I have an HEI then I dont need an external blaster coil right? Would I need any other ignition components besides wires?
1968 camaro
350 sbc
Auto Transmission
You might check their website and see what they offer. If you plan on using your HEI, I believe you would have to get a harness to use the HEI pick-up coil, dispose of the HEI module, as the MSD box would substitute, and use the HEI coil.
I would keep the HEI module in the glovebox just in case of ignition failure to drive it home.
1 - 2 of 2 Posts
